Portable Version als Zip
pela
Has thanked: 11 times
Been thanked: 17 times
Post by pela »
Guten Tag
Ich finde die Portable Version nicht als Zip Datei.
Wo ist die hin gekommen ?
Bei der Neuen Version 8.6.1
MfG PeLa
horst
Been thanked: 40 times
Re: Portable Version als Zip
Post by horst »
Die gibt und braucht es nicht mehr.
Der Installer bietet dir unter anderem eine portable Installation an
pela
Post by pela »
Tag
Ich finde es Schade.
das alte System , war für Mich einfacher , Entpacken und auf das Laufwerk Kopieren.
so sind das jetzt mehrere Schritte.
am Abend mal in Ruhe Testen ........
MfG PeLa
Been thanked: 445 times
You cannot notice the new system, yet as you're updating not from the 8.6 series version. Update of the Portable version to the latest one from any previous EPIM versions is virtually the same - you go to the following page: https://www.essentialpim.com/de/update-check, get the ZIP file, unpack it into the folder of your choice and you're good to go.
This process, however, will be much more easier with the next version update when you update from EPIM 8.6x. In this case EPIM will do all that automatically for you, you will not need to manually download and unpack the ZIP file anymore.
pela
Post by pela »
Guten Tag Admin
Danke für Link
Aber es kommt keine ZIP Datei sonder das
EssentialPIMPro.exe
Kann somit auch nicht Entpackt werden.
MfG PeLa
Good afternoon admin
Thanks for Link
But there is no ZIP file but that
EssentialPIMPro.exe
Can not be unpacked.
MfG PeLa
translated with Google
Please try now, make sure you refresh the page. Thanks.
a8907433
Been thanked: 118 times
Post by a8907433 »
Hello admin!
Yes, and exactly this is a critical point. Already now there are many people, who after a year have troubles with the current version. Then they will wonder, and ask..... I need the version xy, where are the installation files....??? Now, if even the portable version is more comfortable and does all automatically, you will get more ignorant (sorry for this expression, but it´s true) and comfortable people.
It is not sensible to have no copies of important files! And, with an automatic update you will not have one.
You only need to make sure you have copies of your database file. The program itself can always be downloaded from our web site, no need to waste precious SSD/HDD/Cloud space by backing up its installation files.
pela
Post by pela »
guten tag
Mit der Zip Version komme Ich besser klar und habe es Lieber.
Sichern , Entpacken und auf Stick Kopieren.
So ist Mir das Lieb.
Ich habe es nicht so Gerne , wen das Progrumm zu sehr für Mich Denkt.
MfG PeLa
good day
With the zip version I get along better and have it better.
Save, unpack and copy to stick.
That's how I love it.
I do not like it so much who the program thinks too much for me.
MfG PeLa
