Unrecognized UUE encoding scheme
Axel
Post by Axel »
ich kann plötzlich keine Mails mehr empfangen. Es erscheint folgende Fehlermeldung:
"Unrecognized UUE encoding scheme"
EssentialPIM Pro Portable 8.66.1 unter Windows 10
Wo liegt der Fehler?
Gruss, Axel
Been thanked: 363 times
Re: Unrecognized UUE encoding scheme
please post a screenshot of the error.
Axel
Post by Axel »
Hello Max,
I reinstalled EPIM in order to continue my urgent mail communications. I'm sorry but now there is no way to reconstruct a screenshot of the error. But I saved the log file of the error. May be you can use it even in a better way. Here it is:
EssentialPIM Pro Portable 8.66.1 07.04.2020 12:09
12:09:25.657 0 Create
12:09:25.657 Execute begin
12:09:25.673 Retrieve begin
12:09:25.673 Host: pop.1und1.de
12:09:28.850 MsgCount=10
12:09:28.882 NewMsgCount=10
12:09:28.882 Retrieve 1Mr9mq-1iosWd0oWk-00oHKb
12:09:29.810 Size 8868
12:09:29.810 Load OK
12:09:30.278 OK
12:09:30.278 POPDelete 1Mr9mq-1iosWd0oWk-00oHKb
12:09:30.288 Retrieve 1N0oSL-1jG8YW3UUn-00wefE
12:09:30.891 Size 205154
12:09:30.893 Load OK
12:09:31.024 OK
12:09:31.024 POPDelete 1N0oSL-1jG8YW3UUn-00wefE
12:09:31.039 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:09:31.861 Size 73933
12:09:31.864 Load OK
12:09:31.881 Unrecognized UUE encoding scheme.
12:09:31.881 Execute end
12:14:25.660 Destroy begin
12:14:25.660 Cancel begin
12:14:25.660 Cancel end
12:14:25.660 Destroy end
12:14:25.660 1 0 Create
12:14:25.660 1 Execute begin
12:14:25.691 1 Retrieve begin
12:14:25.691 1 Host: pop.1und1.de
12:14:26.045 1 MsgCount=8
12:14:26.092 1 NewMsgCount=8
12:14:26.092 1 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:14:27.010 1 Size 73933
12:14:27.010 1 Load OK
12:14:27.026 1 Unrecognized UUE encoding scheme.
12:14:27.026 1 Execute end
12:19:25.671 1 Destroy begin
12:19:25.671 1 Cancel begin
12:19:25.671 1 Cancel end
12:19:25.671 1 Destroy end
12:19:25.671 2 0 Create
12:19:25.671 2 Execute begin
12:19:25.681 2 Retrieve begin
12:19:25.681 2 Host: pop.1und1.de
12:19:26.094 2 MsgCount=8
12:19:26.134 2 NewMsgCount=8
12:19:26.134 2 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:19:26.980 2 Size 73933
12:19:26.980 2 Load OK
12:19:27.000 2 Unrecognized UUE encoding scheme.
12:19:27.000 2 Execute end
12:24:25.685 2 Destroy begin
12:24:25.685 2 Cancel begin
12:24:25.685 2 Cancel end
12:24:25.685 2 Destroy end
12:24:25.685 3 0 Create
12:24:25.685 3 Execute begin
12:24:25.716 3 Retrieve begin
12:24:25.716 3 Host: pop.1und1.de
12:24:26.087 3 MsgCount=8
12:24:26.118 3 NewMsgCount=8
12:24:26.118 3 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:24:26.942 3 Size 73933
12:24:26.942 3 Load OK
12:24:26.973 3 Unrecognized UUE encoding scheme.
12:24:26.973 3 Execute end
12:29:25.688 3 Destroy begin
12:29:25.688 3 Cancel begin
12:29:25.688 3 Cancel end
12:29:25.688 3 Destroy end
12:29:25.688 4 0 Create
12:29:25.688 4 Execute begin
12:29:25.710 4 Retrieve begin
12:29:25.710 4 Host: pop.1und1.de
12:29:26.074 4 MsgCount=8
12:29:26.112 4 NewMsgCount=8
12:29:26.112 4 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:29:27.045 4 Size 73933
12:29:27.045 4 Load OK
12:29:27.076 4 Unrecognized UUE encoding scheme.
12:29:27.076 4 Execute end
12:34:25.692 4 Destroy begin
12:34:25.692 4 Cancel begin
12:34:25.692 4 Cancel end
12:34:25.692 4 Destroy end
12:34:25.692 5 0 Create
12:34:25.692 5 Execute begin
12:34:25.730 5 Retrieve begin
12:34:25.730 5 Host: pop.1und1.de
12:34:26.031 5 MsgCount=8
12:34:26.078 5 NewMsgCount=8
12:34:26.078 5 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:34:26.902 5 Size 73933
12:34:26.902 5 Load OK
12:34:26.917 5 Unrecognized UUE encoding scheme.
12:34:26.917 5 Execute end
12:39:25.697 5 Destroy begin
12:39:25.697 5 Cancel begin
12:39:25.697 5 Cancel end
12:39:25.697 5 Destroy end
12:39:25.697 6 0 Create
12:39:25.697 6 Execute begin
12:39:25.735 6 Retrieve begin
12:39:25.735 6 Host: pop.1und1.de
12:39:26.082 6 MsgCount=8
12:39:26.120 6 NewMsgCount=8
12:39:26.120 6 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:39:26.953 6 Size 73933
12:39:26.953 6 Load OK
12:39:26.969 6 Unrecognized UUE encoding scheme.
12:39:26.969 6 Execute end
12:44:25.711 6 Destroy begin
12:44:25.711 6 Cancel begin
12:44:25.711 6 Cancel end
12:44:25.711 6 Destroy end
12:44:25.711 7 0 Create
12:44:25.711 7 Execute begin
12:44:25.742 7 Retrieve begin
12:44:25.742 7 Host: pop.1und1.de
12:44:26.097 7 MsgCount=8
12:44:26.128 7 NewMsgCount=8
12:44:26.128 7 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:44:26.977 7 Size 73933
12:44:26.977 7 Load OK
12:44:26.999 7 Unrecognized UUE encoding scheme.
12:44:26.999 7 Execute end
12:49:25.722 7 Destroy begin
12:49:25.722 7 Cancel begin
12:49:25.722 7 Cancel end
12:49:25.722 7 Destroy end
12:49:25.722 8 0 Create
12:49:25.722 8 Execute begin
12:49:25.738 8 Retrieve begin
12:49:25.738 8 Host: pop.1und1.de
12:49:26.092 8 MsgCount=8
12:49:26.123 8 NewMsgCount=8
12:49:26.123 8 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:49:26.979 8 Size 73933
12:49:26.979 8 Load OK
12:49:26.995 8 Unrecognized UUE encoding scheme.
12:49:26.995 8 Execute end
12:54:25.731 8 Destroy begin
12:54:25.731 8 Cancel begin
12:54:25.731 8 Cancel end
12:54:25.731 8 Destroy end
12:54:25.731 9 0 Create
12:54:25.731 9 Execute begin
12:54:25.769 9 Retrieve begin
12:54:25.769 9 Host: pop.1und1.de
12:54:26.132 9 MsgCount=8
12:54:26.170 9 NewMsgCount=8
12:54:26.170 9 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:54:27.003 9 Size 73933
12:54:27.003 9 Load OK
12:54:27.018 9 Unrecognized UUE encoding scheme.
12:54:27.018 9 Execute end
12:55:51.097 9 Destroy begin
12:55:51.097 9 Cancel begin
12:55:51.097 9 Cancel end
12:55:51.097 9 Destroy end
12:55:51.097 10 0 Create
12:55:51.097 10 Execute begin
12:55:51.119 10 Retrieve begin
12:55:51.119 10 Host: pop.1und1.de
12:55:51.467 10 MsgCount=8
12:55:51.498 10 NewMsgCount=8
12:55:51.498 10 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:55:52.416 10 Size 73933
12:55:52.416 10 Load OK
12:55:52.438 10 Unrecognized UUE encoding scheme.
12:55:52.438 10 Execute end
12:58:03.563 10 Destroy begin
12:58:03.578 10 Cancel begin
12:58:03.578 10 Cancel end
12:58:03.578 10 Destroy end
12:58:03.578 11 0 Create
12:58:03.578 11 Execute begin
12:58:03.594 11 Retrieve begin
12:58:03.594 11 Host: pop.1und1.de
12:58:03.964 11 MsgCount=8
12:58:03.995 11 NewMsgCount=8
12:58:03.995 11 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:58:04.844 11 Size 73933
12:58:04.844 11 Load OK
12:58:04.866 11 Unrecognized UUE encoding scheme.
12:58:04.866 11 Execute end
12:59:25.738 11 Destroy begin
12:59:25.738 11 Cancel begin
12:59:25.738 11 Cancel end
12:59:25.738 11 Destroy end
12:59:25.738 12 0 Create
12:59:25.738 12 Execute begin
12:59:25.769 12 Retrieve begin
12:59:25.769 12 Host: pop.1und1.de
12:59:26.108 12 MsgCount=8
12:59:26.139 12 NewMsgCount=8
12:59:26.139 12 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
12:59:27.141 12 Size 73933
12:59:27.141 12 Load OK
12:59:27.157 12 Unrecognized UUE encoding scheme.
12:59:27.157 12 Execute end
13:04:25.741 12 Destroy begin
13:04:25.741 12 Cancel begin
13:04:25.741 12 Cancel end
13:04:25.741 12 Destroy end
13:04:25.741 13 0 Create
13:04:25.741 13 Execute begin
13:04:25.779 13 Retrieve begin
13:04:25.779 13 Host: pop.1und1.de
13:04:26.096 13 MsgCount=8
13:04:26.127 13 NewMsgCount=8
13:04:26.127 13 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
13:04:26.976 13 Size 73933
13:04:26.982 13 Load OK
13:04:26.998 13 Unrecognized UUE encoding scheme.
13:04:26.998 13 Execute end
13:06:46.107 13 Destroy begin
13:06:46.107 13 Cancel begin
13:06:46.107 13 Cancel end
13:06:46.107 13 Destroy end
13:06:46.107 14 0 Create
13:06:46.107 14 Execute begin
13:06:46.123 14 Retrieve begin
13:06:46.123 14 Host: pop.1und1.de
13:06:46.471 14 MsgCount=8
13:06:46.508 14 NewMsgCount=8
13:06:46.508 14 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
13:06:47.010 14 Size 73933
13:06:47.010 14 Load OK
13:06:47.026 14 Unrecognized UUE encoding scheme.
13:06:47.026 14 Execute end
13:09:25.745 14 Destroy begin
13:09:25.745 14 Cancel begin
13:09:25.745 14 Cancel end
13:09:25.745 14 Destroy end
13:09:25.745 15 0 Create
13:09:25.745 15 Execute begin
13:09:25.776 15 Retrieve begin
13:09:25.776 15 Host: pop.1und1.de
13:09:26.130 15 MsgCount=8
13:09:26.162 15 NewMsgCount=8
13:09:26.162 15 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
13:09:27.033 15 Size 73933
13:09:27.033 15 Load OK
13:09:27.049 15 Unrecognized UUE encoding scheme.
13:09:27.049 15 Execute end
13:11:06.227 15 Destroy begin
13:11:06.242 15 Cancel begin
13:11:06.242 15 Cancel end
13:11:06.242 15 Destroy end
13:11:06.242 16 0 Create
13:11:06.242 16 Execute begin
13:11:06.258 16 Retrieve begin
13:11:06.258 16 Host: pop.1und1.de
13:11:06.612 16 MsgCount=8
13:11:06.643 16 NewMsgCount=8
13:11:06.643 16 Retrieve 1MhmCW-1ixCOI41dw-00dq6R
13:11:07.678 16 Size 73933
13:11:07.678 16 Load OK
13:11:07.715 16 Unrecognized UUE encoding scheme.
13:11:07.715 16 Execute end
