Fehlermeldung: Cannot create File
Plato
Re: Fehlermeldung: Cannot create File
Post by Plato »
Zur Ergänzung:
Wenn ich Epim (Windows) neu einlese kommt die Fehlermeldung nicht. Ich kann dann synchronisieren. Aber schon beim nächsten Aufruf habe ich wieder die Fehlermeldung.
Has thanked: 778 times
Been thanked: 411 times
Thanks, now we know the problem is not related to Android synchronization. Sync your database over to the new one using EPIM Sync (https://www.essentialpim.com/de/pc-vers ... ntary-apps), that should fix the problem.
Plato
Post by Plato »
Ok, I have synchronized my Database from local database c/user/HAJ/HAJold.epim to local database c/user/HAJ/HAJnew.epim.
I can open this database, but I have the same problem as before, the same message.
What is wrong?
Plato
Post by Plato »
Keine Idee? Ist die log-Datei denn dort richtig?
Please share a screenshot with a list of all synchronizations that you have.
Also let us know the installation folder for EPIM on your PC.
Plato
Post by Plato »
Thanks so far,
Attached is the sync from my Huawei Cellphone. For the tablet it is the same, only the port is "15".
I have also the folder for Epim and Epim-sync attached.
Epim-Folder.pdf
(236.33 KiB) Downloaded 6 times
Sync Huawei.pdf
(204.42 KiB) Downloaded 3 times
Thank you! Please check if the following folder exists in your system: C:\Users\User_name\AppData\Roaming\EssentialPIM. If there's such a folder, what's its contents?
Or you can always try to install EPIM as a Portable version, that should also help solve the problem. Thanks!
Plato
Post by Plato »
Thanks, I found the attached folder under roaming.
I tried it also with the portable version, but when I open my data i have the same problem and I think I am always back to the Windows version. No sighn of portable anymore.
Roaming.pdf
(184.58 KiB) Downloaded 6 times
Thanks, the problem is with the dash symbol in path. Will be fixed in the next update.
