out of memory
Discuss EssentialPIM in Dutch
Moderators: PeCe, Moozer
martindoornbos
out of memory
Post by martindoornbos »
Hallo er kom geen mail binnen omdat een mail met bijlage te groot is
hoe los ik dat op
groeten
Martin Doornbos
Been thanked: 363 times
Re: out of memory
Reboot your computer and try again.
martindoornbos
Re: out of memory
I have reboot, make a new folder / file, do the optmalisation ect
The problem is een big mail, I can not remove from the server, and PIM not can download
Re: out of memory
Use the web interface to the mail to log in and delete the email.
martindoornbos
Re: out of memory
I have remove the mail from the server, but is tils work now not probply, if a start the program, it go first check de data basefile
and a cannot save the file, the program halts / crache
cassy
Re: out of memory
Post by cassy »
But does the e-mail take so much memory or no? Maybe you should try to minimalize the size of the bilage?
To want to, is to be able to.
