spam
Discuss EssentialPIM in Dutch
Moderators: PeCe, Moozer
Been thanked: 363 times
Re: spam
thank you for the screenshots- they indeed help. Can you also make one screenshot of Tools-> Options-> Spam?
PeCe
Has thanked: 77 times
Been thanked: 262 times
Re: spam
Post by PeCe »
Bedankt voor de foto's, op zich ziet verzamelde adressen er goed uit en zou het dus niet in spam mogen komen.
Zoals Max vraagt kan je ook een foto/screenshot maken van [Extra] - [Opties] en dan kiezen voor [spam]?
tesro
Has thanked: 6 times
Been thanked: 9 times
Re: spam
Post by tesro »
om de nieuwsbrieven uit de spam te halen kun je bovenin de balk klikken op 'geen spam' dan word deze mail uit de spambox naar je gewone emails geplaatst
RuudO
Been thanked: 4 times
Re: spam
Post by RuudO »
[1]
quote:"please check that in Tools-> Options-> Spam there is an option "Exempt message from spam filtering..." turned on (by default it is)
Then right-click on any message that's wrongly identified as spam and choose "Add Sender to Contacts". That should fix it."
uitsluiten spam email.jpg (46.27 KiB) Viewed 45 times
Epim responds with an empty contact page with only the name, I add the email address manually and save that. Result: next time in the spam box.
[2]
There is no option (anymore) to mark a message as spam manually, as far as I have been able to perceive.
(vertaling door Google )
RuudO
Re: spam
Post by RuudO »
[2a] Of is het de bedoeling om de spammail te droppen op deze bak ???? Staat niet in de helptekst..
RuudO
Re: spam
Post by RuudO »
If using more than one mailaddresses (6 accounts), check of all entries are filled in case of spam rules. Found one without rules, after that the spam button arrives on top. Even the spambox is filled with spammail. (..) Solved.
