In the EPIM Today view, I like to have my to-dos separated by day. To accomplish this I made up a todo for each day of the week (i.e. ------Monday-----) and made the start and due date time = to 12:01 am so that it would be the first to-do for the day.
At the end of the day, I change the start/due dates to the the next week.
See attached screen shot
To do Separated by Day of the Week in EPIM Today View
- ToDoWithDays.JPG (34.03 KiB) Viewed 15743 times
Re: To do Separated by Day of the Week in EPIM Today View
Thank you, suggestion noted.
- Has thanked: 1412 times
Implemented in EPIM 6.0 version.
- Has thanked: 5 times
- Been thanked: 54 times
Yes, but that only works if the ToDo item is set to display on calendar (and thus displays in Calendar portion of EPIM Today) whereas obbob is having the day-of-week display in the ToDo portion of EPIM Today.admin wrote:Implemented in EPIM 6.0 version.
HTH,
Matt Z.
EssentialPIM Pro 6.05 on Win7 Home Premium 64 bit SP1
EssentialPIM Pro 3.7.2 on Android 4.1.2 (LG Optimus F3 - T-Mobile)
I was referring to the "By Due Date" sorting option for To Dos. If due dates are set correctly, you will be able to get exactly the same view as obbob suggested (no need to display to dos in calendar then).
On my PC, not exactly...
I get "Tomorrow" and "This Week" not Thursday, Friday, Saturday, which IMO is more useful... besides, it would be nice to have something similar for Start Date.
Okay, point taken, thanks.
