Google Contacts Sync Problem
aphorist
Post by aphorist »
I didn't manage to find this exact problem searching your site so I turn to you. I use Win 7 Home Premium, 64 Bit fully up-dated, on an Athlon triple core with 6Gb RAM. I am using EPIM 5.5 RC2.
I get a message "HTTP/1.0 400 Bad Request" error after the program appears to have worked through importation. The Contacts in EPIM have been imported from a CSV created in Excel 2010. I have had the same problem with earlier versions too. The other sync elements complete.
Hope you can help.
Peter Thomas
Been thanked: 363 times
Re: Google Contacts Sync Problem
Screenshots would certainly help.
jakrzysztow
Post by jakrzysztow »
I too have this problem.
I've attached a screen shot.
Is there a log file somewhere?
Any addition information necessary, just ask!
aphorist
Post by aphorist »
aphorist wrote:Hi,
Hope you can help.
Peter Thomas
Hi Max,
Screenshot as requested and log file.
Peter
EPIM Screenshot.png (1.1 MiB) Viewed 5217 times
GoogleSync_2013_05_22_09_25_54.log
(2.26 KiB) Downloaded 181 times
please go to Tools-> Options-> Synchronziations and enable extensive logging. After that, send me please the log to ma@essentialpim.. WITH a link to this topic. Thank you!
jakrzysztow
Any progress on this?
did you send us an extensive log file? PLease send to ma@essentialpim.. WITH a link to this topic. Thank you!
jakrzysztow
As a matter of fact, I did on May 22nd and sent the same email again today May 30th.
Thank you. It was in the SPAM folder. Now looking at the log.
This error appears when EPIM starts to synchronize Notes. Please make sure your Google Drive account is working and you can log into it from web browser.
jakrzysztow
I have no problems what so ever with Google Drive. Use this a lot for work. Though I have no documents in the root of Google Drive, just "folders"..
At the moment, I've stopped syncing the Notes and no more errors, but any ideas how to resolve this?
paulg
Post by paulg »
I'm also having problems syncing to folders - see screenshot.
If I disable notes sync the error goes away. I can access my Google docs online without any problems
Paul
http://www.ipgphotography.com
EssentialPim-Pro, Windows7 64bit
jakrzysztow
Any progress on this? Want information do you need to help solve this?
jakrzysztow
EPIM 5.55 has fixed my problems associated with this thread!
Jeffrey
Thank you!
