"HTTP/1.1 403 Forbidden" at Syncing with Google
Been thanked: 447 times
Re: "HTTP/1.1 403 Forbidden" at Syncing with Google
Morning. Please check your Google sync settings (Tools->Options->Synchronizations, Google). Which of the modules are enabled for synchronization? Thanks.
Drbo
Post by Drbo »
my problem is, "Your Google Account" link from EssentialPim Window doesn't work... (my default browser is Opera, maybe there is a problem). Can I write web address manually?
MEVCRNA
Post by MEVCRNA »
Hello.
Only calendar sync is enabled. I have tried Epim to Google - no sync, Google to epim - sync, no sync for contacts, notes or todo.
in addition, when I followed a prompt to check consistency, epim tried to optimize the database and crashed.
thanks
MEVCRNA
Post by MEVCRNA »
So near and yet so far. EPIMs sudden failure to sync renders it unusable for my business. Send a notice if you get it working.
regards
LarryW
Been thanked: 11 times
Post by LarryW »
I too have found that using 6.02 allows syncing the calendar but not the Tasks nor a subscribed calendar. Checking the ToDo to sync results in the Forbidden error message but it appears the calendar works fine.
sergioglezgala
Has thanked: 5 times
Post by sergioglezgala »
I have the same error, HTTP/1.1 410 Gone, previously the one regarding "Forbiden". It apeears while syncing Appointments, just when the sync beguins.
Windows 7 Prof.
EIPM 6.02, and previously with 6.01.
Sergio González Galarreta
gmaddry
Post by gmaddry »
Clearing sync data didn't correct the 410 error.
sergioglezgala
I already did it. No.
JUGLANS
Post by JUGLANS »
admin wrote:JUGLANS, are you using a 2-factor authentication with Google? If yes, please see this post by Google:
https://support.google.com/accounts/answer/185833
yes i use2-factor authentication with Google.
I generate password of 16 character but when i paste on code of syncronization option and save, but i receive a message "Invalid Code"
Thank You
Drbo, you cannot unfortunately. Please try setting a new browser as default temporarily and see if it helps. Thanks!
MEVCRNA, please forward us the log file of the latest sync then. Logs files are here: C:\Users\Your_Windows_Username\AppData\Roaming\EssentialPIM Pro\Logs. Thank you.
LarryW, you must be using a 2-factor authentication. If yes, please see this post by Google:
JUGLANS, you should paste that code into the Password field.
JUGLANS
Post by JUGLANS »
admin wrote:JUGLANS, you should paste that code into the Password field.
Sorry, now ok.
But i have the same problem of
MEVCRNA
Post by MEVCRNA »
Thanks for your continuing attention. It is rare to get support for software and I do appreciate the help.
Just for completeness.
I am using EssentialPIMPro Portable
System Windows 7/8
Latest log attached
Thanks again.
GoogleSync_2014_11_23_17_58_51.log
(3.82 MiB) Downloaded 60 times
