I created a new category and then created a task with that custom category assigned. Then (after closing the task) I deleted the category. I expected that the task would have no category anymore, but it had one. It was the one before the deleted category in the categories list (maybe just a coincidence).
(version 7.53 pro portable)
Unexpected category on task after deleting category
Re: Unexpected category on task after deleting category
Thank you. I could not reproduce that behaviour, however.
Can you reproduce that case on a new database? If yes, could you post some screenshots demonstrating the problem?
I created a pdf with screenshots and description of each step. For this test I created a new database (EssentialPIM 7.53 Pro on Windows 8.1 x64 German).
Note: When I deleted the category the task was closed. The deletion was done using the edit -> categories main menu entry.
Thank you, issue reproduced, will fix.
