Can sync with Android phone be scheduled? Or do I have to create a recurring task with an reminder so that I do it manually?
I see how I can create the recurring task, but how do I make sure the reminder will fire off at the same time each day on a recurring basis?
Scheduled synchronization with Android
- Has thanked: 2 times
- Been thanked: 9 times
- ecsaltz
- Has thanked: 30 times
- Been thanked: 77 times
Re: Scheduled synchronization with Android
+1 If EPIM can't do it currently, this would be a great enhancement. Sometimes, I forget to synch and this would solve that problem.
This feature has been available for quite some time now. Please start the app and tap on Menu->PC Sync to turn on the Auto-sync feature and set its interval.
- ecsaltz
The Auto-sync feature apparently doesn't work if the PC -> Android only one way sync is used. I use my EPIM PC -> Android in a "parent object -> child object inheritance" manner. So changes to the EPIM PC I want to regularly sync to the EPIM Android - I don't make changes to the Android because I don't want to deal with resolving possible change conflicts between the two.
So, could Auto-sync be made to work with one way syncing?
There's no difference whether you use a 2-way or a 1-way sync direction, the feature should still be operational.
- ecsaltz
It's working now, I am not sure what I did to make it work - but I have seen some screwy things happening with EPIM synching that I believe has nothing to do with EPIM itself, it might be an issue in my local area wired/wireless networking.
Glad it's working and thanks for the update!
