7.63 Update: Task list now opens to the bottom of the list
rgrun1
Has thanked: 7 times
Been thanked: 4 times
Post by rgrun1 »
I did the update yesterday and now whenever I open to the tasks module it goes to the bottom of the list. This is changed behavior as it always opened at the top. It is not remembering the last state (if it is supposed to do that) as I almost always close with the top of the list in view
Rick
EPIM 7.63
Windows 10 x64 Pro
Rick
EPIM 10 beta2
Windows 10 Pro
Re: 7.63 Update: Task list now opens to the bottom of the list
I can not reproduce it on 7.63. Can you make a video or a couple of screenshots, demonstrating the issue? On my tests Tasks module opens in same position as was when you are leaving the module.
rgrun1
Post by rgrun1 »
Rick
EPIM 10 beta2
Windows 10 Pro
on a video I can see that it opens to the bottom of the list. However, as I mentioned earlier, if it at the bottom of the list when you left the module- this is by design. Please make a video when you leave the module- it is scrolled to one position, then you enter the module and it is another position- this might be a problem.
rgrun1
Post by rgrun1 »
Thanks I will watch for that
Rick
EPIM 10 beta2
Windows 10 Pro
