Just reporting:
There are two missing labels on the PT-BR language, they show a "%d" and a word that doesn't make sense in the context. Always saw them on updates.
Here are the screenshots.
Missing Labels PT-BR
Re: Missing Labels PT-BR
Thanks for the report! What should translations for the missing phrases be? It should say "Download & Install" on the button for the first pic. And where the second dialog window is coming from?
"Download & Install" should be "Baixar e Instalar".
I think the second one comes before the first one I posted. Then, when I click "sim", the first one open. Not that sure though, I might look at it on the next update.
Thanks, will fix in the next update.
Which version you're updating from? Should be ok on 9.9.
I wasn't sure, but I always update it when it asks.
Now the labels aren't missing, but they are in english, which I think it's fine. If you want to translate it, then:
"Download & Install" = "Baixar e Instalar"
"New Version Check" = "Checagem de Nova Versão"
"To continue with EssentialPIM update installation, EssentialPIM will restart." = "Para continuar com a instalação de atualização da EssentialPIM, a EssentialPIM será reiniciada."
Thanks! Will include the suggested translation into the language file.
