cannot write key information
a8907433
Been thanked: 170 times
Re: cannot write key information
Post by a8907433 »
What if you manually write the key in the .ini file and save it (portable version)? Save it in the .ini and open it afterwards to see, if it is saved. If it is saved, I can not imagine, that EPIM does not accept or overwrite it- it has to work. If not, than Windows prevents you from saving and writing. Another possibillity would be, to look into the Windows registry. Here you can look at the correct key or correct it if wrong (installed version).
GKDantas
Post by GKDantas »
Just get into the me problem after format my machine, any idea about this problem?
Frank-H
Has thanked: 40 times
Been thanked: 4 times
Post by Frank-H »
GKDantas wrote: Sat Jul 31, 2021 4:47 am Just get into the me problem after format my machine, any idea about this problem?
This makes no sense, especially resurrecting a 2 year old post. What are you trying to say?
GKDantas
Post by GKDantas »
Dont work, everytime I open the app it says t my serial expired
Anotação 2021-07-31 110207.png (9.6 KiB) Viewed 1096 times
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Where do you find the ini file (path)?
a8907433
Post by a8907433 »
You use the portable version. So, the EssentialPim.ini is in the same folder where you stored the portable version, in the program folder you choosed for the portable version.
poet-man
Post by poet-man »
Sorry ... my question obviously was misunderstandable.
Ich wanted to say @GKDantas, to please tell us, where (in his case) he found the ini file (exact path).
In addition to that the date of the file might be of help
GKDantas
Post by GKDantas »
Hi here is the path for the portable version
H:\GKDantas\Utilitarios\EPIM (same path installation of Epim)
Both INI files are from the same date 31/07/2021 (07/31/2021)
Even running Epim as ADM it cant write to the ini file (the INI file already have the data with my key)
poet-man
Post by poet-man »
Why I asked, was, that several months ago, I had the same problem. But I cannot recall, how I solved it.
What I DO remember is, that I realised, in my case, that Windows7 redirects directories, so that no harm can be done to the originals. It uses a directory "VirtualStore".
Some files donot exist, where one would guess, they are, but in that redirected directory.
In my case (I installed with standard values), essentialpim.ini exists in "C:\Users\<username>\AppData\Local\VirtualStore\Program Files\EssentialPIM Pro\EssentialPIM.ini" - searching for the file, I will find it there.
In there I will also find my databases (in directory ..\database).
Program however will tell you, that it's C:\program Files\EssentialPIM Pro where everything is in. This redirection thing (VirtualStore) doesnot give you any writing rights there however.
Please donot ask me, what this is all about. I donot even know, whether this fact had something to do with my solution, those days. I understood those days, but donot have the time now, to reread reunderstand etc.
But thought these words might help somebody. If not, I'm sorry ... just wanted to try to help
a8907433
Post by a8907433 »
What, if you just copy this portable EPIM folder, transfer it to another computer and try it there? Either you habe a second computer, or just ask a friend. Will it work there? And, after you tried this and transfer it back to your computer..... will it work there?
GKDantas
Post by GKDantas »
Will try on another computer today, just reintalled Windows in a friend notebook, lets see whats happen.
GKDantas
Post by GKDantas »
Ok, just copyed the portable folder and one database to a clean notebook (asus i5 5200). Deleted the INI file and Epim asked for registration as usual, after enter the key for the first time everything was fine until I close the program, wait and start it again, the same problem occur, maybe a problem with my serial.
You're using an older license key that doesn't include updates to the latest version and the message states that.
GKDantas
Post by GKDantas »
Yes, but one is a lifetime for shure, just sended the emails when i bought them
