Hi
I am using 8.63.
I imported Formula one calendar and there's no way to edit/delete any of them because everything is greyed out.
Could you help me how I can modify/edit/delete? Thank you very much in advance
Cannot delete/edit imported calender (read-only cannot uncheck)
Re: Cannot delete/edit imported calender (read-only cannot uncheck)
please go to Tools-> Options and check "Subscriptions" and "Synchronization-> Google" Appointment belongs to one of those. You can remove calendar/subscription.
Thank you Max for a quick reply.
I am sorry I was not clear; F1 calendar is not subscription or synced calendar.
It was downloaded and imported manually as ical.
Thank you so much
Thank you so much
Do you have an example of such ical file? I would like to reproduce the problem. Please upload it here or send to ma@essentialpim...
- Has thanked: 11 times
- Been thanked: 13 times
I have this issue too. I have a old loaded iCal Calendar that I cannot remove, for it is greyed-out & read-only.
In my case I seem to remember it was once part of my Google profile. I believe in that I imported this calender in my Googly Calendar, and recently I removed it from my Google Calendar, with the intention to included it as a EPIM ical Subscription. But I never properly unloaded the subscription from my Google sync with EPIM, and that is why I believe it is still part of my EPIM database. I think that EPIM, as a consequence, marked these items as greyed-out & read-only, for the source is no longer available to EPIM (no longer part of my Google Calendar). I hope Max can see if such a scenario is possible, for I am only remembering and speculating . Due to the greyed-out & read-only status I cannot remove the items myself, and that is a pity.
Just my thoughts on this. Hope it helps
Finally found it. I forget which F1 calendar I downloaded.
https://www.racefans.net/contact/f1-fanatic-calendar/
Here, I think I downloaded the ical version but possible I clicked "Add to F1 session times to your calendar".
Hope you can help me get rid of them. Thank you in advance.
It does not look like imported iCal. As I mentioned above, please go to Tools-> Options and check "Subscriptions" and "Synchronization-> Google". You can remove calendar/subscription.
Max,
I don't have subscriptions to delete.
You have synchronisation with Google calendar. This particular calendar (F1) may be added to your calendar as read-only calendar and the events coming from there. Check Tools-> Options-> Synchronization-> Google and see if you have this calendar (F1---) synchronised with EPIM. Uncheck it, synchronise again and events will dissapear.
Thank you Max! This was it! I can see it on Google Calendar on the webpage as "subscribed" and synced with my Epim as read only as you guessed it right.
Apologies I didn't remember correctly since it was long time ago.
