Pro 8.64 Desktop Calendar Tasks scroll
glenn59
Has thanked: 24 times
Been thanked: 11 times
Post by glenn59 »
After selecting calendar mode, mouse wheel will scroll both "Date blocks" panel and "Tasks" panel when the pointer is over the panels. However, once either the "Date blocks" panel or "Tasks" panel is selected, mouse pointer location recognition ceases functioning. Selecting "Title Bar" of either panel does not refocus pointer location. Behavior remains the same until another module is selected in the "Modules panel on left, and reselecting "Calendar" module, then behavior of mouse location recognition returns to normal. Selecting in either panel to refocus has resulted in inadvertently marking a task as completed, or inadvertently opening "New Appointment" popup.
Being able to refocus pointer by selecting panel's title bar would be an optimal solution. (Please)
Windows 7 system, Desktop Pro 8.64 version
EPIM Android Pro v5.7.1 -Samsung Galaxy S5(SM-G900V) - Android OS v5.0
EPIM Portable Pro V6.0 RC2 - Windows 7; XP
EPIM Desktop Pro V8.64 - Windows 7
