New lines in lists converted to new items
lk
Has thanked: 19 times
Been thanked: 7 times
Post by lk »
Hi there,
hopefully the last bug I found today:
Inside of an unordered list in a task, it is possible to create a line break inside of a list item by pressing Shift-Return:
However, if I save the task by pressing the "Ok" button and reopen it afterwards, the line breaks are converted into new list items:
(I can only reproduce this issue in the "Tasks" module. In the "Notes" module, the Shift-Return feature works as it should!)
(EPIM Pro 8.66.1 Lifetime on Windows 8.1 64 bit)
lk
Has thanked: 918 times
Been thanked: 530 times
Re: New lines in lists converted to new items
Thanks, will attempt to fix.
lk
Post by lk »
Hi again,
if you're looking at it: I just noticed in the "Notes" module that Shift-Return only works with unordered and ordered lists, but not with checklists. Of course it would be nice if checklists could use this feature too - sometimes it's more clear to use some newlines/blank lines inside of a checklist.
lk
Sure, will do look at that, as well.
lk
Post by lk »
Hi there,
v9.5.2 (portable Pro version) still shows this bug... has anything happened here in the meantime?
lk
Working fine for us. Please try on a new database, will there be the same problem?
lk
Post by lk »
Tried it with a new database and created a new task there.
Before saving the task:
After clicking Ok and doubleclicking on the task:
It looks as if it works for the second line of an item while the third and all following lines get converted into new items.
lk
Confirm, will attempt to fix in the next version.
lk
Post by lk »
The Shift-Return key combination also works differently with checklists compared to unordered/ordered lists. The behavour of the latter is more useful IMHO.
lk
Which checklists do you mean? What are unordered/ordered lists? How can we check this out?
Keldi
Has thanked: 21 times
Been thanked: 75 times
Post by Keldi »
In notes (an animated gif in the attachments).
lk
Post by lk »
Yes, it's exactly this effect I meant.
lk
I see now, thanks. Will attempt to fix in the next update.
