icloud sync - contacts
@ndreas
Been thanked: 4 times
Post by @ndreas »
icloud --> Epim sync; contacts have no photo :(
Best regards
Andreas
Win 10 Pro x64 - EPim Pro 9.x - Lifetime subscription to EssentialPIM upgrades
@ndreas
Re: icloud sync - contacts
Post by @ndreas »
same in 9.1
Best regards
Andreas
Has thanked: 934 times
Been thanked: 554 times
Thanks for reminding us about the issue. Will try to address it in the next version.
@ndreas
Post by @ndreas »
same in 9.1.1
Best regards
Andreas
Unfortunately due changes on the iCloud side syncing of contact pics is not possible anymore (at least until a workaround solution is found).
@ndreas
Post by @ndreas »
Too bad, eM Client, for example, shows the contact pictures without problems.
Best regards
Andreas
Interesting, will check it out, thanks.
@ndreas
Post by @ndreas »
Feature in 9.3
Synchronization of contact pictures with iCloud works again
No, it doesnt work! :?
343 contacts - no pictures.
Best regards
Andreas
You need to delete contacts from WinEPIM, clear up iCloud sync data from File->Database Management and then sync again. You'll then end up with newly received contacts with pictures. Just make sure you backup your database before doing that, please.
@ndreas
Post by @ndreas »
Thanks, it works! :)
Best regards
Andreas
