I am using EPIM Windows and Android with 2 way sync. When i edit a note in windows everything is ok, but when i open the note with android my tables are not there and when i sync back again from my android to windows, the tables also are gone and the images are back to the original scale.
I tested several times and this keep happening. So far, as i said, it seems it is only the tables that disappear and scaled images go back to original size when i use 2 sync
Is there anything i can do to solve this?
Problem with EPIM sync to Android
- Has thanked: 1418 times
Re: Problem with EPIM sync to Android
Unfortunately tables is notes aren't yet supported in AEPIM.
