EPIM 9.0 Read-Only switch not always showing toggling back on.
lbw2112
Has thanked: 7 times
Been thanked: 4 times
Post by lbw2112 »
I have a lot of notes set as Read-Only. If I need to edit one, I right click and select "Read-Only" to toggle it off, edit it and then turn Read-Only back on and that usually works fine.
I noticed though that sometimes it won't toggle Read-Only back on after changing the note.
After trying to reproduce when this happens, it seems like I can edit the note fine and it will turn Read-Only back on like it should.
But if I turn off Read-Only and add or change a Tag, then it doesn't turn Read-Only back on and I have to exit and restart and it will show correct.
I'm using the release version of 9.0 in Dark Mode.
Thanks,
Larry
lbw2112
Re: EPIM 9.0 Read-Only switch not always showing toggling back on.
Post by lbw2112 »
EssentialPIM Pro 9.6.1
This has started happening again with the newest release.
It's random. Some notes I can turn Read-Only off and on fine, other ones I can't turn on Read-Only. There's nothing special about the ones that work or don't work, they're the same format in title and note content.
Thanks,
Larry
lbw2112
Post by lbw2112 »
I've been playing around trying to find what the trigger is that causes this problem. It seems it may be on notes where I enter tags into the note body with the hashtag in front (#Tag1 #Tag2) and EPIM adds those tags to EPIM Tags in the note, which is what I want.
After I tried this out with a few notes I found that before adding the tags this way that I could set it to Read-Only, but after adding the tags and hitting enter to go to a new line is when I couldn't set it to Read-Only.
I don't know if this reproduces the problem every time but in the few new notes I tested it did.
Has thanked: 934 times
Been thanked: 554 times
I think we were able to reproduce the issue. Will be fixed in the next release, thanks for mentioning additional details about it.
