Sticky note whenever I press the letter s it goes to insert date.
lbw2112
Has thanked: 4 times
Post by lbw2112 »
Not sure if this did this before 9.1 since I don't use it much, but whenever I press the letter s key in a Sticky Note it pops the Insert Date window open. I have the insert Date shortcut set to F4 and the other shortcuts all pretty much to None except one or two.
Thanks,
Larry
lbw2112
Re: Sticky note whenever I press the letter s it goes to insert date.
Post by lbw2112 »
Duplicated this on a seperate computer.
It appears that typing the letter s is tied to the F4 key somehow in the program.
When I changed the shortcut of "Insert Date" from F4 to None or something else it I can type s in Sticky Note with no problem. When I change it back to F4 the letter s pops the "Insert Date" open again.
I use the F4 key in many programs for insert date so I don't want to have it different in EPIM.
Thanks,
Larry
