Weird Behavior on Dragging Tasks to Calendar
hamiltonfsj
Post by hamiltonfsj »
I was having some problemas by dragging tasks onto the calendar. I figured out that it behaviors based on what position my selected day is.
Sometimes, it drags correctly.
Sometimes, it drags to other day.
Sometimes, it gives me an error.
I have 4 sets of screenshots with 2 images each.
The first image shows what day I selected.
The second image shows the result on trying to drag the task to the selected day.
Has thanked: 779 times
Been thanked: 411 times
Re: Weird Behavior on Dragging Tasks to Calendar
It works ok on our side. Please check if updating to the 9.1.1 version will improve the situation. If not, would appreciate if you record a small video demonstrating the problem. Thanks!
hamiltonfsj
Here it is. The first one indicates the different behaviors (dragging correctly and dragging to other places). The second one is the error that happens when a day is not selected.
2020-07-03-14-01-25.mp4
(1.11 MiB) Downloaded 4 times
2020-07-03-14-06-19_1.mp4
(440.02 KiB) Downloaded 1 time
Thank you! Reproduced both issues, will be fixed in the next update.
