9.1 bug - Quick Search ignores "'s
MetalDrop
Been thanked: 143 times
Post by MetalDrop »
9.1 bug - Quick Search ignores ( " )'s
Windows 7 64-bit US-ENG & Windows 10 64-bit US-ENG, Intel i7 7700k, 32GB DDR4, Nvidia & AMD Ryzen 2600 16GB DDR4 Nvidia 1080ti
[I'm helpful and often reply to questions, please note however I am just a fellow user and not staff.]
Keldi
Has thanked: 9 times
Been thanked: 34 times
Re: 9.1 bug - Quick Search ignores "'s
Post by Keldi »
Isn't that symbol excluded because it's a special symbol in quick search that allows to make searches like this:
"find this" NOT that
(to find notes that have the words find this but don't have the word that)?
MetalDrop
Post by MetalDrop »
Keldi wrote:
Wed Jul 01, 2020 8:03 pm
No quick search works that way by default it is not an incremental search.
If you search for:
Find this
You will only get results that contain: Find this
You will not get results that only have "Find" or "This"
Also in the screen shot I show two "s however a single one will be ignored as well which even if wuick search was incremental should not be happening.
Been thanked: 363 times
Thank you, will look into this. I am not yet sure although what the fix will be.
