Epim v9.1.1 upgrade issue
dmdcissp
Post by dmdcissp »
Whenever I try to upgrade to 9.1.1 it tells me that Epim pro is still running and it will not allow the upgrade to proceed.
I have checked many times in the task manager and it is not running.
Dave D.
Has thanked: 823 times
Been thanked: 449 times
Re: Epim v9.1.1 upgrade issue
Dave, please reboot your PC that should help to resolve the problem. Thanks!
dmdcissp
Post by dmdcissp »
That worked, thanks for the quick response.
Does this mean that we should reboot before applying an upgrade?
Quite controversy, meaning you shouldn't be normally rebooting your PC. Only in some rare cases when EPIM couldn't close itself correctly, reboot might be required.
