EPIM no longer syncs with Android app
rdg170
Post by rdg170 »
EPIM will no longer sync between the desktop and the Android app. It was working fine until the most recent Windows 10 update. My phone is on my home wireless network, but EPIM Android no longer finds my computer.
- I've checked the firewall settings on my computer, since I sometimes get that message on the Android app.
- I have gone carefully through your troubleshooting points and the knowledge base on your support site.
EPIM Pro 9.1.1
Windows 10 Home, Version 1909
64-bit operating system
Android 7.1.2
Thanks for your help.
Has thanked: 778 times
Been thanked: 411 times
Re: EPIM no longer syncs with Android app
If you try to use the Manual Sync option, will it work?
rdg170
Post by rdg170 »
The sync no longer works when I launch it from the app including from the "connect manually" command. Nothing.
Is there any error message when you try to sync manually?
