Custom Fields
bobmac1547
Custom Fields
Post by bobmac1547 »
When I imported contacts and tasks into EPIM via CSV, some custom fields were created. After transferring the data to other fields, I no longer need those fields.
In each form, there is a trashcan icon next to the field. Does that delete the field from the database entirely? or just from that record?
And what about the "X" at the right side of a field? Does that hide or delete the field from that record?
Been thanked: 445 times
Re: Custom Fields
The field will be deleted from the database.
Could you please upload a screenshot here showing which "X" you mean?
bobmac1547
Re: Custom Fields
Here's the screenshot
Re: Custom Fields
Thanks! This just hides fields from the view.
bobmac1547
Re: Custom Fields
Is that record-specific or does it apply to all records?
How can I unhide a field previously hidden?
Re: Custom Fields
It applies to all records. To unhide a filed, simply click on the "Add New" button.
Keldi
Has thanked: 15 times
Been thanked: 47 times
Re: Custom Fields
Post by Keldi »
admin wrote:
Wed Sep 16, 2020 9:51 am
It shouldn't delete the content of the field?
Let's say, I have contact1 & contact 2, and in a custom field there are 'sample text 1' & 'sample text 2'.
I click on X near the custom field in the contact 1 --> the field is hidden.
With 'Add New' to unhide:
- in the contact 1 I'll get the empty field ('sample text 1' was erased),
- in the contact 2 I'll get the field with 'sample text 2' (the data is intact for every contact, except the one in which I clicked on X).
(An animated gif is attached).
Re: Custom Fields
It probably shouldn't. Will check if this is something we can easily fix for the new relese.
