Drafts
Essy
Drafts
Post by Essy »
I left 2 unfinished drafts open overnight. Every minute a copy is saved, showing a popup message.(can that be switched off?_
On EPIM
- 2 drafts in the Drafts folder.
- 1650 drafts in the All Mail folder.
On GMail
- 1650 drafts in the Drafts folder.
I think this could be improved a little in a future version :wink:
Been thanked: 447 times
Re: Drafts
What sort of a popup message did you see? Could you please provide its screenshot?
As for the number of saved Drafts - please forward me the log file via PM (Tools->Options->Synchronization, Browse... and the filename should start with "Mail") Thanks!
Essy
Re: Drafts
Post by Essy »
I've PMed the screenshot and log.
I'm not sure you received it. It says "Message successfully sent". But the message stays in my Outbox and isn't moved to the Sent folder.
Re: Drafts
Got it thanks!
About sending out private messages - that's how forum software works, is shows the message in Outbox until the recipient reads it.
