Bug in memberships
bobmac1547
Bug in memberships
Post by bobmac1547 »
Using EPIM Pro 9.3, Win10-64
I cannot place contacts in memberships (Why aren't they called GROUPS, anyway?)
Cannot activate field in contact form.
Click ... at right of field and empty window opens with no way to add groups. Only OK And Cancel buttons.
Am I missing something? Or is this a known issue? (I see in the forums that it was a previous issue that was apparently fixed, but it seems to have reared its ugly head again. :( )
Been thanked: 445 times
Re: Bug in memberships
Do you have any contact groups? If not, you should add them first, only then you'll be able to see them in that window.
bobmac1547
Well, I finally found how to add groups. It would be great to add a button in the popup window to do just that.
Got it, will do make that change.
