Dynamic SQL error code 104
andreev@akkon-bg.com
Post by andreev@akkon-bg.com »
I have a lifetime Bussines license, and today I made an update from V 8.66 to V9.3.
When the new version opening DB, an error appeared. See att. file
How I can fix the problem.
Been thanked: 447 times
Re: Dynamic SQL error code 104
Please install Firebird 2.5 either by redownloading EPIM Business and choosing this option or from the official web site: https://firebirdsql.org/en/firebird-2-5/
Thank you. Now work fine.
Hello again,
Acording your instruction I uninstall old version and reinstall Firebird from the EPIM Pro Businses V9.3 installation pack.
The server pc work fine , but the all client pc has a problem.
Before update to V9.3 , to run EPIM Pro ( client PC ) over the local network we need a few seconds. Now we need more from 3 minutes.
Do you have any idea why this is so ?
You mean opening a database file over the network from client PCs takes roughly 3 minutes now? If so, does it happen from all of the client PCs? If you create a new test database file and try to open it from a client PCs, will it be faster?
Yes , opening a database file over the network from client PCs takes roughly 3 minutes now. Yes it happen from all of the client PCs. I created a new DB test file , and opening it is not faster
Once a database is opened, you're able to work with it normally? Maybe you should try to uninstall and then reinstall Firebird again, seems something's wrong with it.
Hi, I found the problem. The old version of the fireburd was active, and in the task manager we have two version loaded. The right solution is , before install new version of Fireburd , be sure to uninstall the old version!
Now EPIM Pro Bussines , work fine and quickly from all workstation. I am very satisfied and recomendetit to all business client.
Awesome, thanks very much for the update!
