New version 9.4 freezing and unusable
Re: New version 9.4 freezing and unusable
Will you be able to click on the Send button in order to forward us details via email?
- Frizzell9
- Has thanked: 30 times
- Been thanked: 15 times
I tried screen recording while using the 'Notes' module, but after many minutes of trying to get the 'freeze up' error I stopped recording. Let me just say this. You have dramatically improved the freezing/lockup issue, but it is still not totally fixed, giving a much less frequent error lockup. I'm unable to be more specific as to how, what and when, so perhaps someone else will be able to assist you better in fixing whatever final bit of code it is to bulletproof the 'Notes' module. In the meantime, I am going to go ahead and continue to use the newest version and try not to work too heavily with 'Notes for now. I know you will stumble on to it sooner or later so I can live with it.
Thanks Team EPIM!
One of you oldest users, Frizzell9
Thanks Team EPIM!
EPIM Pro User Since 2006
Once you happen to see the error message again, please check if you're able to click on the Send button and forward us the report about it. In this case we'll be able to get it fixed sooner. Thanks!
- Frizzell9
It's Friday, Oct, 16, 9:00am
I just hit Send on an Error. I can't tell if you got it or not, so let me know if you saw it around 9am.
Frizzell9
Thank you! Should it have been from the same email address that you used for registration in the forum? If so, then we didn't get anything from you, unfortunately.
