9.4 opens to a blank/void? note rather than the one you left off on.
- Been thanked: 8 times
After updating to 9.4 when starting EPIM with the note module the last note being viewed is no longer restored instead it just puts you to a null/void/nothing/blank but not editable note.
- Has thanked: 901 times
- Been thanked: 518 times
Re: 9.4 opens to a blank/void? note rather than the one you left off on.
Will there be the same problem if you redownload and reinstall EPIM 9.4?
- Has thanked: 11 times
- Been thanked: 13 times
It is true that I have downloaded the 9.4 version that was accessible on sept 30th and since then a new version is out (also named 9.4), but I have no other serious issues (I read on the forum about instances of a freezing EPIM). So reluctantly upgrading to a newer 9.4...
Indeed, the newer version loads the last Note as expected (here with me).
Tam
Tam
Just downloaded fresh and replaced [portable version] and that did seem to fix the issue.
Thank you all for the confirmation!
