New note in AEPIM - change size to 11 - sync - change size in EPIM to 10 - sync - just modify text in AEPIM and not size - sync - the size rises to 11 in EPIM
EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
- Laurent C.
- Has thanked: 4 times
- Been thanked: 12 times
Re: EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
Tried the new process a second time : here the 10/11 switch / very strange
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
I think you're running into a different bug.
If the only thing you change in AEPIM is font size than AEPIM doesn't save the changes to the note. [video attached]
- video_2021-01-15_12-14-35.mp4
- (1.41 MiB) Downloaded 116 times
- Laurent C.
It's not what I've done and it's between default 10/11 sizes, not 14 :
- Laurent C.
See EPIM video to the end :
I used 14 in that video to better show the bug I was reporting as 10-11 is so minute it's hard to see at a passing glance.Laurent C. wrote: ↑Fri Jan 15, 2021 9:26 pm It's not what I've done and it's between default 10/11 sizes, not 14 :New note in AEPIM - change size to 11 - sync - change size in EPIM to 10 - sync - just modify text in AEPIM and not size - sync - the size rises to 11 in EPIM
- Laurent C.
Thanks, I perhaps did not understand always very well English as a French people
When I try AEPIM 14 font size, it goes back to size 11 again at the end !?
I'm not having exactly your behavior in my case without understanding that
All of this to say anyway to EPIM team that there is a little mess in the code : the sizing should be in coherency always between EPIM PC and EPIM Android...
Thank you again for your support MetalDrop
Rgds
Rgds
So, just being the girl who points out the obvious here, but why not just change the default font size in AEPIM to 10pt to match the PC version and be done with this? Since it seems like this whole thing is really just based around the 1pt default size difference causing strange bugs in some circumstances that require a lot of work to setup.
- Laurent C.
I just agree with that
But I'm not the developer of the solution, and I do not understand why having chosen different sizes, and what implies for the future a full coherency between Windows and Android...
I let EPIM Team to make its own analysis of this strange situation that seems simple to me, but could be more complex : I don't know ?
And more complex is possible, since I have tried the 14pt option of MetalDrop that does not sync to 14 at the end : something new again in my understanding = I really don't understand this unfitted behavior...
Regards
Regards
- Laurent C.
And, thank you Triple S for your collaboration
- Laurent C.
Ce n'est pas corrigé pour EssentialPIM 9.8 + EssentialPIM for Android 5.8.1 = vous confirmez ?
- Laurent C.
Not fixed
EPIM Android changes note size from 10 to 11 without any reason !?
And if modified in Outlook, it goes back to size 10
Weird and not nice at all...
- Laurent C.
Hi
This is shortly a one-year bug , simple, but not yet fixed using AEPIM with EPIM Pro 9.9.7...
Rgds
- Laurent C.
EssentialPIM for Android 5.8.6 Released : bug is not fixed too bad...
- Laurent C.
Not better with EPIM pro 9.10.6 last release
At the beginning, in 2020, it seems to me a simple issue with a minor sync mismatch in your RTF/HTML format...
Rgds
Rgds
