EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
- Laurent C.
- Has thanked: 4 times
- Been thanked: 12 times
Hi
Default Arial 10 text is resized wrongly to 11 by EPIM Android !?
This has several sides effects
To reproduce :
Create an Outlook note
Sync to EPIM PC then to EPIM Android
EPIM PC is Arial 10
Open note in Android and click in the content and use back button to do nothing
Unfortunately, the note is saved
Sync all again
The Arial 10 goes 11 inside EPIM PC and modification goes to Outlook
Bang !
Too bad
Regards
To reproduce :
EPIM PC is Arial 10
Sync all again
Bang !
Too bad
Regards
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
- Has thanked: 1418 times
Re: EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
That's an issue on the AEPIM's side, will fix.
- Laurent C.
Thank you
- Laurent C.
Hi, nothing has changed with EPIM 9.5 : not fixed yet ... Regards.
- Laurent C.
EPIM 9.5.1 : not fixed...
Since this is an issue with the android version you should be watching it's updates and not the desktop versions.
- Laurent C.
The difficulty is that we do not see easily the Android version update as EPIM: and the updates also seems very very very rare... Regards.
That's because they're all managed in the PlayStore like other Android apps so there's no reason to post them here as anyone using the android app will be using the PlayStore to keep it updated.Laurent C. wrote: ↑Fri Nov 06, 2020 11:48 pm The difficulty is that we do not see easily the Android version update as EPIM: and the updates also seems very very very rare... Regards.
Just like the desktop version they post update info with each major update: That said since this is a pretty minor issue it might not get added to the list of new feature, but it's also pretty easy to tell there's been no update that could have fixed it yet as:
The last AEPIM update was: July 2020
And this issue was brought up: Oct 2020
Which isn't too rare for an android app... not made by a major publisher. Places like Google spam minor updates to their apps like crazy because they can. Which can make it seem like other apps never get updated, but really 2-3 updates a year is a pretty reasonable for a mobile app.
The other thing is for smaller places I've heard Google can keep updates in review forever...They warn up to seven days, but I've been told by some people it is taking over a month to push an update sometimes, and even longer if Google decides to flag something. Which makes it quite unappealing to push minor updates and encourages you to hold them back for a month or two and roll them into a bigger update unless they are substantial issues.
- Laurent C.
I perfectly understand the Android principles
But I do not agree with you : many apps get updates often ; every day/week sometime....
The EPIM update is extremely scarce...
A minor issue is not a reason not to update for 6 months
That's absolutely contrary to agility manifesto
Regards
Regards
- Laurent C.
Nothing better with EPIM 9.5.2
- Laurent C.
Nothing better with EPIM 9.6.1
Please do not post the same reply all over the forum.
- Laurent C.
I hoped at least one was done : I understood = I will post only for a real new Android version next time to really check issue correction
- Laurent C.
Android EPIM 5.8 : Not fixed = I'm waiting next AEPIM version... Regards.
Should be fixed in AndroidEPIM 5.8. Please record a small video showing the problem on your side, will check it once more.
