Laurent C. wrote: ↑Wed Jan 13, 2021 5:18 pm Hi
I can’t download the video in Attachments : ERROR / File too large: 20210113_111454.mp4
It is written : If you wish to attach one or more files enter the details below. You may also attach files by dragging and dropping them in the message box. Maximum filesize per attachment: 10 MiB.
However, my film is 3 MB only, and yet above the ERROR !?
Regards
EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
- Laurent C.
- Has thanked: 4 times
- Been thanked: 12 times
Re: EPIM 9.4 Pro 32 bits - Default Arial 10 resized to 11 by EPIM Android
I cannot reproduce with a video because of :
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
- Laurent C.
I ASSURE You it'd not working
For uploading videos here I recommend using vidcoder:
https://vidcoder.net/
and setting the preset to 1MB target size.
- Laurent C.
Thank you MetalDrop for VidCoder
There is a bug in the forum, because I didn't quote myself here : Regards
- Laurent C.
Hi
With last fixings in AEPIM 5.8, not need for a complex video
Default Arial 10 text is resized wrongly to 11 by EPIM Android !?
To reproduce :
Create an EPIM PC note Arial 10 by default
Sync with AEPIM
Open the AEPIM note and click inside text then click save button
Sync with AEPIM again
Open the note in EPIM : the Arial 10 goes 11 inside EPIM PC
Too bad
Regards
To reproduce :
Sync with AEPIM
Too bad
Regards
Sure you're actually using 5.8?
It isn't even showing up for me on the Playstore yet. Still only says 5.7.4 from July.
- Laurent C.
Hi MetalDrop, I used the Back to the Future accelerator : EPIM.apk Rgds.
- Laurent C.
EssentialPIM for Android 5.8 Released : Please note, this is a staged roll-out release, which means it might take some time till it reaches your Android devices...
- Laurent C.
To easy reproduce Arial 10/11 size EPIM/AEPIM bug...Laurent C. wrote: ↑Thu Jan 14, 2021 11:07 pm Hi
To reproduce :
Sync with AEPIM
Too bad
Regards
Could not reproduce with your provided steps. I tried both just clicking inside the text and editing it in Android 5.8. [see attached video.]Laurent C. wrote: ↑Fri Jan 15, 2021 6:17 pmTo easy reproduce Arial 10/11 size EPIM/AEPIM bug...Laurent C. wrote: ↑Thu Jan 14, 2021 11:07 pm Hi
To reproduce :
Sync with AEPIM
Too bad
Regards
Note: This test was done with a new database from Desktop 9.6.1 and a new fresh install of 5.8
- Video_2021-01-15_095607.mp4
- (1.17 MiB) Downloaded 119 times
- Laurent C.
Yes, you have reproduced in your video: didn't you see that Arial 10 versus 11 ?!???
The Arial 11 is in the note that was made in android , and is what android is set to make notes at.Laurent C. wrote: ↑Fri Jan 15, 2021 7:06 pm Yes, you have reproduced in your video: didn't you see that Arial 10 versus 11 ?!???
The note made in Desktop never changed from Arial 10.
- Laurent C.
You have strictly followed the process : create new EPIM note 10 - sync - modify AEPIM note - sync - read EPIM note resized 11 ? Regards.
Indeed, and here's another video without a note created in AEPIM so that way you never see size 11.Laurent C. wrote: ↑Fri Jan 15, 2021 8:00 pm You have strictly followed the process : create new EPIM note 10 - sync - modify AEPIM note - sync - read EPIM note resized 11 ? Regards.
- Video_2021-01-15_110955.mp4
- (1.21 MiB) Downloaded 121 times
- Laurent C.
Hm, disturbing : trying again ... you' re right and I do not understand the mistake I have done previously !?!!! Searching...
It happens with my 1st note before 5.8 but not the new !?
I've tested a new note in AEPIM - change size to 11 - sync - change size in EPIM to 10 - sync - just modify text in AEPIM and not size - sync - the size rises to 11 in EPIM
A little bit weird for a test, but just to demonstrate there is a glitch with default EPIM/AEPIM sizes and on several conditions
Rgds
Rgds
