Unexpected results when creating tags in sticky notes
DG
Beta Team
Been thanked: 8 times
Post by DG »
The behavior of tags when creating them in a sticky note is different from creating them in a regular note.
When you create a tag in a regular note (type the hash tag (#) followed by the name of the tag), EPIM assigns the tag to the note and displays it in the tags field.
The same action in a sticky note, however, behaves differently. EPIM creates the tag, which you can verify in the Tags Exporer, but it doesn't assign the tag to the note or display it in the tags field. You have to manually assign the tag to the note by going into Tags Explorer and ticking its check box.
I understand that EPIM does not display the tags field in a sticky note, but I would still expect the new tag to appear in the base note's tags field.
Thanks for considering this adjustment.
Regards,
DG
Has thanked: 901 times
Been thanked: 518 times
Re: Unexpected results when creating tags in sticky notes
Will improve, thanks for letting us know.
