9.7 new indent shortcut doesn't work in sticky notes
S_Belle
Been thanked: 4 times
Post by S_Belle »
The new Ctrl+M and Ctrl+Shift+M indent shortcuts don't seem to be working in stickynotes.
DG
Beta Team
Has thanked: 16 times
Been thanked: 33 times
Re: 9.7 new indent shortcut doesn't work in sticky notes
Post by DG »
Confirmed. The indentation doesn't appear in the sticky note, but the text in the main note is indented.
Also, decrease indent (Ctrl+Shift+M) does not work.
Noted about stickies, thanks.
DG, you likely use the Ctrl+Shift+M shortcut for something else. Check for it in the list of shortcuts and remove.
DG
Beta Team
Post by DG »
You're right about my shortcut. EPIM assigns Ctrl+Shift+M to New Message by default. I turned off that shortcut and decrease indent now works.
Thanks,
DG
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Yes, the same with me ... Ctrl-Shift-M only works, if shortcuts are reset to standard.
