If you get this popup during V7 upgrade just Clk Re-Try and the Install completed for me.
EPIM closed the open app (Help / Chk for Updates method) during the process but this popup still showed EPIM open - (Edit) Although Task Mgr showed NO 2nd EPIM.
Same popup on On 9.6.1 & my note said -- Clk Re-try After Re-Start -- , but here it was -- just Re-Try -- right after the popup & Install Completed.
Clk Re-Try for V7 Upgrade Error Popup
- Has thanked: 14 times
- Been thanked: 24 times
EPIM PRO LIFE 11.8.4 - Win 10 Pro - 22H2 --- ESET EIS Prem - Mbam Prem - Diskeeper Pro '15 - Macrium Pd v8
Re: Clk Re-Try for V7 Upgrade Error Popup
Thanks - Forgot to mention nothing showed in Task Mgr but, per above, the install completed with just Clk'ing Re-Try.
- Has thanked: 1418 times
Likely EPIM was still shutting itself down when you got that message. And it had finished with the process when you hit Retry.
Thnx. It's happened on 3 Updates so far & I bet there is something about the Chk for Updates method I always use that causes this.
Remembering to Clk Retry is not a big ask.
All is well.
All is well.
