Clicking Conversation below e-mail enables conversation but label doesn't change
Telesto
Post by Telesto »
Clicking Conversation below e-mail after clicking 'Email in the navigator bar' toggles conversations on, but label doesn't change into something like "conversation off" indication you can use it to turn it off.
And personally I find it really strange place to put that entry. Feels kind of mismatch with the design. Other entry's fit. Not seeing a 'proper' place though. Kind of thinking of a button somewhere.. Or a shortcut for turning it on/off.
Re: Clicking Conversation below e-mail enables conversation but label doesn't change
The conversation feature changes the view, so it at least partly is a fit to where it belongs now. Although, if you think there's a better place, let us know, will consider that.
Telesto
Post by Telesto »
I think a (toggle) button in the quick filter bar being best location. Conversion is something similar to 'show unread messages only' (it's grouped in the menu similarly) or "starred only"
The sidebar thing is pure confusion. The others make sense, but 'conversation' doesn't fit in, IMHO (can't exactly tell why, but feels wrong). Doesn't look nice either, with collapsed sidebar (as if 'conversation' would be a different tab; which it isn't)
Ok, thanks for your explanation, noted.
