The socket error is self-induced (so not the issue). However the button are really unhelpful here.
Stop task -> The task is already halted
Stop all? -> All tasks are already halted (finished or connection error)
Hide -> No I have a connection error..
So I really want to 'resolve' the issue. So I'm searching for 'retry/restart'. Or if this more permanent? A help button? Or Configuration button (assuming wrong configuration)..
However this is simply leaving me in the dark what I'm supposed to do [Stop All tasks & re-click Send/Receive is the ultimate solution), but this really can be made more user friendly
And while at it, what does the pin button supposed to do in the send/receive dialog. It has no hoover over info tooltip and not sure what I should pin
Send receive dialog confusing after Socket Error
- Has thanked: 1412 times
Re: Send receive dialog confusing after Socket Error
Thanks for the suggestion, noted.
The pin button allows you to always see the dialog window even if it should be hidden after all the tasks are completed.
