Bug: 9.7.5 Notes
MetalDrop
Been thanked: 189 times
Bug: 9.7.5 Notes
Post by MetalDrop »
If you type a font name, you can't then immediately change the font size because the selected text will loss it's selection.
[video attached In the video I try to change the font by typing the font name and then trying to change the size 3 times, at the end of the video I select the font with the drop down and change the size to show that it works fine when using that method.]
Video_2021-03-20_080212.mp4
(1.12 MiB) Downloaded 74 times
ecsaltz
Has thanked: 30 times
Been thanked: 77 times
Re: Bug: 9.7.5 Notes
Post by ecsaltz »
MetalDrop wrote: Sat Mar 20, 2021 4:05 pm If you type a font name, you can't then immediately change the font size because the selected text will loss it's selection.
v9.7.5 I repeated what you did, but the text stayed highlighted and I was immediately was able to change the font.
I don't know why it works for me, and not for you - sorry, I can't be more helpful.
MetalDrop
Post by MetalDrop »
Here's another video from another computer.
This time I'm showing that it happens in 9.7.5 but not in an earlier version of 9x
I have tested this on 7 different computers and they are all effected by this.
Video_2021-03-21_194507.wmv
(2.76 MiB) Downloaded 72 times
Has thanked: 1411 times
Been thanked: 984 times
We were able to reproduce the issue, thanks. Will be fixed in the next update.
