adding ical to esspim 5.7.5 pro
can't seem to add holidays to pro(seems to have dropped out during one of the updates) they(.ical files)come in zip files.downloaded but can't figure out how to import to esspim pro.could someone give me step by step starting from winzip...thanks Tim
- Has thanked: 1425 times
- Been thanked: 991 times
Re: adding ical to esspim 5.7.5 pro
Android EPIM is not able to import iCal files as of yet. You can import them into WinEPIM and then sync AEPIM with WinEPIM to get the holidays shown in AEPIM, as well. Thanks.
In this case you should unpack the zip file and then import the resulted *.ics file into WinEPIM by clicking on File->Import->Calendar->iCal.
