Deleted Tasks Keep Appearing
- Been thanked: 1 time
Deleted multiple sub-tasks and they show back up after I close (to the system tray) and then reopen after about 15 minutes. I have Pro 9.7.5. It is synced with my Android phone. Is there a log file that I can look at that will tell us what is going on? How do I trouble shoot this?
Re: Deleted Tasks Keep Appearing
You can check for the log files here: Tools->Options->Synchronization, Browse...
Are you able to reproduce the issue? If so, will it happen if you disable any sync for a while?
Yes I can reproduce all the time. Ok I have turned off synching. I'll try to reproduce the issue to see if synching was part of the issue and report back to you.
Ok I have been testing it with the sync disabled. In fact I deleted the sync (Android phone) on the PC side. The problem disappeared so obviously the issue is with the sync. I am going to recreate the sync and see what happens? Should I do something else?
I have recreated the sync and synced a couple times and no deleted tasks reappear. I have manually created a couple tasks from the laptop, synced, verified they are on the phone, deleted them from the laptop, synced, verified they are still gone, and resynced and verified a couple times. So far it's working. I am going to do the same thing but not sync after the deletions and let the phone sync on it's own schedule and see what happens. I'll let you know.
It appears to be working. Please close this issue. Thanks for the support!
