Pasting notes between trees
tahoma
Has thanked: 11 times
Been thanked: 13 times
Post by tahoma »
If one copies and pastes multiple Notes to other locations, the pasted Notes do not end up beneath the last Child Note, as one would expect, but mixed up between the existing Child Notes. This can be improved, for now it requires unnecessary extra ordering from the user...
Thanks!
Between notes and between tree notes, behaviour is not consistent
Re: Pasting notes between trees
What are you notes sorting settings?
tahoma
Post by tahoma »
It says 'Custom order", but it is all default. This is a portable instance of EPIM that I use to check behaviour I experience with my day-to-day database.
I did it again, thoroughly! I deleted the EPIM.ini file, so this EPIM is initiated afresh, then I create a new database, and add two root notes and a couple of subnotes to them. The behaviour is as recorded in my previous video's. My conclusion is that this behaviour is coded per default in EPIM, and it is not really related to user settings.
Thank you
I see, will have a look at this, thanks.
