I have various problems with anchors. For better understanding I would like to describe the situation step by step:
1. Let's assume I would like to create an anchor for the line with the text "3) Sonstiges" in the following picture:
So I select e.g. the "3)" (or alternatively it seems to be enough to click on the line).
2. I click on the anchor button in the toolbar:
3. In the opening window ("Anchors") I add my preferred name for the anchor, for example "Anchor 3":
4. Now I want to link to this anchor. In most of the cases I do this in a table with the contents on top of the note (quite similar as it can be seen e.g. in articles in Wikipedia):
So I select e.g. the number "3)" in the table, then I click on the Hyperlink button in the toolbar and the window "Insert Hyperlink" opens:
In this window I click on "Browse".
5. A new window opens where I choose the anchor to which I want to link (in my case "Anchor 3" in the note "ABHOLEN"):
I think I did all in the correct way so far.
And now I see two problems:
6.
Problem 1: The hyperlink is not created in the selected text - in my example: "3)" - but appears left of it (with the formerly selected text appearing a second time):
Obviously this is a bug and I think it was already reported by some user in the past but at the moment I cannot find the thread again. So I would just like to get the confirmation that the bug is known and will be fixed.
7.
Problem 2: Jumping to the anchor does not work correctly.
EPIM has to methods to open a link - and I assume these methods apply too when it is not a link to another item but to an anchor:
a) "Ctrl + left mouse click" opens the link in a separate window. --> This method works.
b) "Alt + left mouse click" opens the link in the same window. (That means in case of an anchor: I can jump within the note directly to the line where the anchor is set.) --> This method does not work. With "Alt + left mouse click" nothing happens.
Problems with anchors
Re: Problems with anchors
The duplicate link text issue was already fixed in a "hidden" update. Which means you are using the more broken 9.7.5.
You should download a new copy of 9.7.5 manually, as the auto-update system doesn't seem to catch the hidden version number-less updates.
- Has thanked: 17 times
- Been thanked: 8 times
In the meantime I found it: viewtopic.php?f=2&t=35744
But anway MetalDrop posted the solution:
It works now.* Thank you!
*[Edit: Not really. See my next post.]
[PS: Just that it is not overlooked: the other issue mentioned above still exists.]
Edit:
No, not completely!
It depends on how you create the anchor link:
A) It works when the anchor link is created via clicking on "Browse" in the window "Insert Hyperlink" and than navigating in the list to the anchor name (as shown in my first post in the picture under Nr. 5).
B) The bug still exists when choosing "Copy Anchor As Link" from the context menu of the anchor and then pasting this link into the field "Item link" * (again in the window "Insert Hyperlink"). (Maybe one time it works. But the next three times or so it does not.)
*[which should better be named "Item / Anchor link"]
And by the way: The (very important) "Undo" command often does not work too. (E.g. now when I try to remove these undesired additional entries caused by the anchor link creation.) I click the "Undo" button and absolutely nothing happens. But I am not in the mood now to open the next thread for this issue.
A critical remark: I see these bugs even as a newcomer in using the program, but the developers did not discover them before releasing it? Don't you test the basic functions before a release? It is so complicated and time-consuming to describe all these issues.
- Has thanked: 1412 times
Point B is also fixed in the internal builds. Thanks!
This issue (= b) continues to exist (or it is here again - I don't know) in case that anchor and hyperlink are in the same note.Tester wrote: ↑Sat Apr 03, 2021 7:45 pm
You mean in the same note and in the same leaf or in the same note but in different leaves?
I mean in the same note and in the same leaf. (I can't tell about the situation with different leaves because until now I only have notes with one leaf.)
I see now, thanks. Will improve this.
