Cannot see contact in event
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Hi there,
usually I create events in AEPIM on my tablet. Then sync it to WinEPIM on notebook.
Out of the blue I wanted to check where I can see the contact I had chosen in AEPIM in the event (a contact from contacts module).
As synced to WinEPIM, I thought it should be there. But I cannot see/find the contact in the event in WinEPIM.
Should it be there or is there any technical reason why it is not synced over to notebook.
Of course I can create a link in the event to that contact in WinEPIM, as the contacts are there in contacts module. But just as link from sync, it does not seem to exist.
Can anybody tell me why?
Regards
Axel
Re: Cannot see contact in event
There's no such feature to assign contacts to events in WinEPIM, yet.
poet-man
Post by poet-man »
But I can add a link to a contact in an event in WinEPIM. Isn't this what I do in AEPIM and should be visible in WinEPIM as well after sync?
Nope, that's interlinking.
poet-man
Post by poet-man »
I understand.
Nevertheless I donot understand, why a contact, added in an event in AEPIM, is not set in the event in WinEPIM as well. In my opinion the event should be as close to the original as possible.
I agree and the feature is in the to do list. Will be implemented soon. Thanks!
