In the notes module, when I type @ to summon a link to a contact, EPIM redraws the note screen and deletes the @. When I type it again, it works as expected and does not delete the sign.
It seems to be happening only if there are already links to contacts in the same note. Typing @ on new notes and old notes without links is working fine.
I could make links via the menu but this is much faster.
EssentialPIM pro deletes the @ sign
- Has thanked: 1412 times
Re: EssentialPIM pro deletes the @ sign
What's your EPIM version number? This should have been fixed in the 9.7.5 version.
- Has thanked: 11 times
- Been thanked: 13 times
I reported this (viewtopic.php?f=2&t=35862), and admin has already confirmed that in the internal builds it has been repaired. But the solution is not yet out. I reported it on March 16., and 9.7.5. was already released (March 9.)
Ok, thanks, will be fixed in the upcoming 9.8 version.
