DropBox link needs fixing
Peter_in_Stirling
Been thanked: 4 times
Post by Peter_in_Stirling »
I've got a DropBox connection question which I'll raise in another post. In the meantime, a long-time gripe has been the alignment of items in the box which pops up when one needs to link to a file in DB. What is step 1? (I'm trying to use v. 9.8, but I've had this problem with all earlier versions).
best wishes,
Peter Mayer
Has thanked: 1411 times
Been thanked: 984 times
Re: DropBox link needs fixing
What's your scaling setting in Windows?
Peter_in_Stirling
Display is set for 100%.
Is that Windows 10? Please make a screenshot that shows the Scale and layout settings in Windows and include it into your next post. Thanks!
Peter_in_Stirling
It is Win 10. Here's the screen shot that I think you want.
Thanks, so it's 125% after all, not 100% :) What you can do now while we're working on a fix is to temporarily switch to 100%, restart EPIM, authorize yourself on Dropbox (the window works as expected on 100%) and once this is done, go back to 125%.
Peter_in_Stirling
Thanks. I'll try it shortly.
