hello,
just to inform that some ink colours does not work any more, for example : I like velvet coulor to write my mails and it's grey
that's not a big problem, but it is one since EPIM proposes this choice !
essentielPim Pro 9.8 windows 10
thanks for all !
nathalie
problem with the choice of ink color
- Has thanked: 1412 times
Re: problem with the choice of ink color
nathalie, does it happen all the time? If so, could you please record a small video demonstrating the problem? We weren't able to reproduce it so far, unfortunately.
- Has thanked: 25 times
- Been thanked: 11 times
hello !
thanks for the answer.
yes it happens all the time.
I have checked if the problem appears elswhere than the mails, but no, it is only with the mails.
I can send you an e-mail with the velvet ink settings, so that you can see it is not velvet but grey.
Thank you! Although it seems you forgot to attach the file (link to a file) to that email. You can also forward it to me here in the forum via PM.
thanks for your answer
there was no file attached, the mail was enought at is own : I set Purple ink for the mail I sent you one to show you that it appears grey !
We use a third-party customer support system which doesn't really support proper html formatting. So a small video would still be helpful.
