EPIM - Windows and iOS
awilsmore
Post by awilsmore »
I am using EPIM Pro, 8.5, Windows 10 64 bit.
It's a long story, but I wish to keep a tree-structured set of notes to use and update with a friend of mine. The Notes tool in EPIM is ideal.
My friend is Mac user, so I got him to download from here: https://www.essentialpim.com/ios
I them emailed him the set of files containing the Notes (and nothing else) I had created.
.backup
-common
.epim
.history
.options
.private
But... he cannot open these and cannot see Notes in his version of EPIM.
Is there anything we can do to be able to work together in EPIM Notes?
AW
Re: EPIM - Windows and iOS
iOS EPIM isn't really for Mac. You can use EPIM Cloud service or Google Drive, for instance. In this case your friend will be able to edit the notes on Google Drive via browser and you'll be able to sync them with EPIM. You'd both need to have access to the same Google account, though.
