Error on Exiting EPIM
I get this error often when exiting EPIM. There is nothing wrong with my internet connection. Why does it happen and what can I do about it?
- Has thanked: 1418 times
Re: Error on Exiting EPIM
That is likely related to storing your database in Dropbox. Please remove it from Dropbox (Tools->Options->Dropbox) and then re-add it back using the same method.
I did what you suggested and the error still appears. I need to store the database in dropbox so that I can access it from two different computers.
What's your EPIM version number? Does it happen all the time or just time to time?
The latest version 9.8. It happens every time I exit EPIM at the end of my session in front of the pc. Then when I restart EPIM and exit again the uploading database is successful perhaps at the second or third attempt.
Create a new DB and move it to Dropbox, will there be the same problem with it upon closing EPIM?
