Synch proplem
Haldex
Has thanked: 25 times
Been thanked: 5 times
Synch proplem
Post by Haldex »
The Caldav synchronisation of the calendar no longer works. The following message is displayed. "HTTP/1.1 403 Forbidden Task: A Third Party" in German: "HTTP/1.1 403 Forbidden Task: Ein Drittes". The specifications are the same as for another Carddav synchroniser. This one works well and reliably. Basically, the information should be correct.
Re: Synch proplem
Please forward me the log file so that we could check what's going on during the sync. ​The file can be found here: Tools->Options->Synchronization, Browse... Thanks!
Haldex
Re: Synch proplem
Post by Haldex »
Sent by PM
Haldex
Re: Synch proplem
Post by Haldex »
It is working now, re-entered the credentials...
